Crowe
Apr 02, 2021Explorer
5th wheel hitches
OK, so the first two responses on my question gooseneck vs. regular pin hitch don't give me warm fuzzies. Sooooo, it's been almost 20 years since we had our fifth wheel. One of our biggest issues wa...
MFL wrote:Ron3rd wrote:MFL wrote:
On new/newer trucks, with thinner bed metal, or aluminum bed, I would not use any single point attachment hitch, from any hitch maker. Just attaching to the ball only, and using the bed for stability can cause truck bed damage/deflection. Andersen does not make a hitch to fit the FW pucks. An adapter would be needed to attach to the pucks, and a 4-point steel Andersen hitch to fit the adapter.
Jerry
MFL I think you're referring to the Aluminum Andersen that mounts to a gooseneck ball in the bed. That's the only attachment to the truck. In a way I agree with you on that style of hitch. I'm not a fan of that style but a lot of people run them and like them.
I'm running the Steel Anderson that mounts to Industry Standard Rails like many other fifth wheel hitches. The load is carried by the frame brackets under the bed and not the bed itself so it's no different from a normal fifth wheel hitch in that respect.
I didn't have the puck system so I went with Pullrite Industry Standard Rails allowing me to use the Andersen, Superglide, or whatever.
Yes Ron3rd, that was my reference. The OP wants to use the puck system directly, and that is a very wise decision! I think if a person doesn't mind rails, the steel Andersen can be a good setup, if you prefer that type of hitch. I was unaware of Lippert's possible objection.
I feel the puck system is the future, as it allows superior strength, while allowing a smooth bed when wanted. I do not understand Andersen's reluctance to build a puck fastening hitch!! This would be easy for them to do, and a step into the future!
To the OP.....You will be very happy with every feature of that 3300 B&W for Ford oem under bed puck system. Congrats on making that choice!
Jerry
