MFL wrote:
On new/newer trucks, with thinner bed metal, or aluminum bed, I would not use any single point attachment hitch, from any hitch maker. Just attaching to the ball only, and using the bed for stability can cause truck bed damage/deflection. Andersen does not make a hitch to fit the FW pucks. An adapter would be needed to attach to the pucks, and a 4-point steel Andersen hitch to fit the adapter.
Jerry
I disagree, same as the B&W add those shims in the valleys on the bed ,there will be no deflection . I do agree ,an adapter ,and the steel Andersen is the "ONLY" way to go . Its too bad Andersen does not supply them with the aluminum hitch , like B&W did after having bed damage with their hitches . IMO any fifth wheel up to 18K GVWR the steel Andersen would be my choice every time, now that I have towed a few thousand with it, regardless of having to go the adapter. There are at least three of those adapters available to attach to the OE puck systems on the new trucks . It enables any rail mount hitch to be attached at all four points to the adapter.
