NC_Hauler
Oct 15, 2013Explorer
arnko37 wrote:
One of the weak spots on a 5th wheel is tire blowouts. When looking at used 5th wheels look at the brands on all the tires. If they are not the same9all different brands) you know this rig has the problem. I had a 30 ft fiver that had 15 inch wheels and had the problem. My present rig is also 30 ft but has 16 inch wheels rated 80 lbs.( and I keep them at 80 lbs) and no problem.
A lot of it depends on the weight of the 5er...also the age of the tires, and being aired to the correct psi...
It is a very good idea to check out the tires on the unit...a good point to be sure.
About Fifth Wheel Group
19,039 PostsLatest Activity: Jan 28, 2022
