mileshuff
Nov 01, 2015Explorer
Searching_Ut wrote:
I feel the push of diesels in with my 5er just as much as with my assorted TTs over the years, and must admit I notice it even when the I'm not towing anything.
Its a matter of how it is felt, not if. With a TT you'll often have the pull then push effect as a semi rig passes. First it pushes against the TT and thus rear of the TV which causes the TV to be pushed toward the semi. Then as the rig passes it begins to push against the TV. True that with a proper setup much of this can be eliminated. Its easier to get rid of such effect with a 5'er.
With a 5'er this effect is nearly unheard of. It pushes on TT and TV as one unit together, no push/pull effect.
About Fifth Wheel Group
