Second_Chance
Jan 03, 2018Explorer II
azdryheat wrote:
Best thing to do is to wander dealer lots or visit an RV show.
X2 ^^. While you're doing that, keep in mind the rear axle capacity of your 2500HD and use 23% of the fifth wheel's GVWR off the sticker for an estimated loaded pin weight - NOT the published pin weight from the manufacturer. Many fifth wheels in the range you are describing will have more pin weight that you can safely put on a 3/4-ton truck.
Rob
About Fifth Wheel Group
