davonelsonExplorerMar 25, 20145th Wheel TiresI have a 36ft 5th Wheel in need of tires. It weights 14,700 lbs loaded but has three axles with 16 inch tires. What is the very best tire I can buy for it?
FastEagleExplorerMar 25, 2014The GY LT235/85R16G tires are the only 16" LT tires that will equal or exceed your OE tires.They are also steel carcass tires.There are others from off shore manufacturers that I'm sure someone will point out.FastEagle
Related Content5th wheel tires5th Wheel took out rear window5th wheel tire reviewTires on a 5th wheel and aggravationTire recommendations for 5th wheel
