Do you have 80 psi wheels or 110 psi wheels? The G614 and Sailun are 110 psi tires.
If by wet you mean loaded for travel then the Michelin XPS Ribs are great tires for lighter weight trailers. For that weight you should have something in the range of 9,000 lbs on the tires. The Goodyear Endurance ST is a relatively new tire that seems to get good reviews. I believe it is an 80 psi tire.
