cummins2014
Apr 25, 2014Explorer
NC Hauler wrote:45Ricochet wrote:
What is the measurement from the ground to the top of your gate? My 06 is 58" but she squats a good 4" when hitched up.
IIRC NChauler has a 2013 dually 4x4 and his is 58.5", but it only squats about 2". Then I read he put new springs on the RV which most likely raised the 5er a bit. Your numbers don't sound real good as is though. You might try the new higher rated spring first, next I'd be looking at adding a sub frame.
Good Luck
True statements Rick, but having towed this 5er more recently, I believe my truck is squatting about 3" also...I took my 5er up to WVa last Wednesday and I measured distance of top of tire to wheel well and the truck squatted 3", not 2"...my bad on that one. The new spring packs raised my unit "right at" 1"...I now have "just over 6" of clearance between the 5er and the bed rails...I've taken some downhill sharp corners as well as backed 5er up my driveway, (bout like Ricks), level off with 5er first and still have a good 1.5" left to play with...Can't see where I could tow this 5er now and get into trouble with it, (my Reese hitch also pivots fore and aft as well as side to side).
When I put my picture frame adapter in, I had to lower my hitch down one notch to make up for extra added height of the picture frame adapter. My 5er is setting "more level" with this truck than it did the 07.5 Chevy dually and the 2010 and 2012 Ram Dually's...
Jim, These new Rams seem to be growing, my 2014 Megacab 3500 sitting level in the garage is 59.5 " to the top of the tailgate . I would love to be 58" it would really help me get a little more level , can't go down anymore then I am , and still maintain enough clearance between bed ,and trailer. This new truck is about three inches taller then the previous truck , but the fifth wheel pushed down my Ford 350 further then I liked, so I went to air bags to level some, with this new Ram it only sits down a little over 2" ,levels the truck which puts me pretty much at the same level as I was with the ford, but still a little high in front, which I see is pretty common on these new trucks.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
