Second_Chance
May 22, 2020Explorer II
What is your tow vehicle? Your question is overly simplistic and the proper answers are complex. A lot has to do with the payload capacity of your tow vehicle (not just the "max towing capacity" usually touted). Find some good sources on towing and read, read, read. The average fifth wheel RV will put 21 - 23% of the GVWR or loaded weight (not empty weight) on the pin. A travel trailer will typically put 10 - 12% of it's GVWR or loaded weight (again - not empty weight) on the hitch ball. IN NO CASE should you consider the published empty hitch weights. They are almost meaningless. A very common mistake of first-timers is to buy too much RV (especially fifth wheels) for their truck. It's less expensive to buy the right equipment the first time than to have to up-size your truck or down-size your RV.
Rob
Rob
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
