todd j wrote:
With this set-up will it support the rack with a 200# generator on it?
If my welder says mine will support 300 lbs without an issue, I'd say "yes". As I said earlier, my bumper was replaced with a heavier tube (stinky hose will no longer fit) and the receiver welded to the bottom. Get an aluminum rack to save a little weight, too. You might also want to, somehow, secure each end to the bumper to keep it from rocking too much. Either that, or replace the bumper tube and weld on TWO receivers! :-)
Lyle
