northmeck0255
Jun 12, 2016Explorer
Let's look at this from an engineering standpoint.
The "bed deflection" you speak of could only be transmitted via the frame of the hitch. The Andersen has a square base, which distributes any forces to 4 sides.
A "traditional" hitch has 2 rails. Simple logic would say that each of those two rails would be under more stress in a normal fiver hitch than any of the 4 sides on the base of an Andersen.
3000 lbs pin weight equals 1500 lbs per rail on a traditional.
3000 lbs pin weight equals 750 lbs per rail on an Andersen. Please explain how half of the force exerted would result in more damage......
If you have empirical evidence to the contrary (not opinion), then I'm all ears.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
