JIMNLIN
Oct 29, 2013Explorer III
Dayle1 wrote:JIMNLIN wrote:
The 5th wheel hitch simply does not will not pivot as much as a GN ball.
There is no technical reason that a 5th wheel hitch couldn't be built to pivot more. But there is also no technical reason that it needs to pivot more because it can't pivot any more than the 6" or so space between the fiver overhang and the pickup bed side rails.
5th wheel hitches with side to side articulation aren't designed to use the full 6"-8" of distance between the sides of the bed and the bottom of the 5er. My 5th wheel hitch stops articulating long before bed contact unlike the GN set up talked about which is one big reason the OP gave us his reasons for using the ball hitch setup.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
