me2
Aug 22, 2015Explorer
JIMNLIN wrote:
I'm 49k miles and close to seven years on the 2nd set LT215/85-16 E on a 11200 lb trailer. It gets new rubber next spring.
Ran the 1st set on this trailer for 55k miles and seven years.
Just curios but where did you find a zero off set 7.5" trailer wheel ??
Those 265/75 tires can have a 10-11" section width....did you have to mod the wheel well for enough side clearance ??
I'm running the stock wheels with no problems.
265-235 = 30mm wider. 30mm/2 = 15mm closer to the frame, a bit over 1/2".
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
