Colo_Native
Jul 26, 2015Explorer
7 pin plug question
I have my new FW and was wondering when parked over night say in a Walmart lot with no power source do you leave the FW plugged into the truck and does it draw off the truck battery?
Arcamper wrote:
My new Ram keeps the plug hot all the time.
tdst51 wrote:tvman44 wrote:
Agreed Ford factory wired do not because of relay.
I wish mine did. We had to move out and away from the driveway and I left it hooked up for about 3 weeks, and when I went to move it back, guess what? Dead battery in my truck.
MFL wrote:
Old Biscuit, on the newer Fords, the top (indent) is at the 3 o'clock position. So yes, you are correct, if the plug was installed like picture, the battery/charge would be at one o'clock.
The Fords have the 4-pin, and 7-pin, side by side, their reason for doing this. I actually like being plugged in with the door on the right, rather than the top.
Jerry
Old-Biscuit wrote:Colo Native wrote:Old-Biscuit wrote:
Flip open 7 pin receptacle cover on truck and test for 12V at 1 O'clock blade.
Truck key off.........no 12V------no drain on battery
Even if there is 12V power with truck key off........overnight stop should NOT drain truck battery unless trailer battery is really low/bad
Boondocking-----YES unplug
I went and checked and mine is the 10 and 5 o'clock pins and there is no power when off. THANKS Everybody
That sure isn't trailer/rv standard truck receptacle wiring
10 (11)....S/B tail/running lights & 5 S/B .....brake controller output
Did you have to rewire your trailer cord plug to match truck receptacle?
