huntram
Apr 09, 2018Explorer
The fifth-wheel coupling provides the link between a semi-trailer and the towing truck, tractor unit, leading trailer or dolly. Some camper trailers use a fifth-wheel configuration, requiring the coupling to be installed in the bed of a pickup truck as a towing vehicle, and "fifth wheel" is therefore sometimes used as a synonym for such campers in North America. The coupling consists of a kingpin, a 2-or-3 1/2-inch-diameter (50.8 or 88.9 mm) vertical steel pin protruding from the bottom of the front of the semi-trailer, and a horseshoe-shaped coupling device called a fifth wheel on the rear of the towing vehicle.
So actually it doesn't matter how many wheels your tow vehicle has! :)
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
