Tom_Diane
May 30, 2013Explorer
fj12ryder wrote:In the scenerio you give, you would not be allowed on that road with a trailer wider than 8'. in fact, it would be closed it would seem.For what its worth, a standard low boy trailer can be 8' to 8'6. Any wider than 8'6 and you better have your oversize load flags on and the red flags where needed and a D.O.T. premit. I doubt you would run into a situation where loads 8'6" are prohibited but if there was a restriction, I beleive it would be 10 ft or wider, other than that there might be a restriction for oversized loads and 8'6 wide is not an oversized load. Several years ago I was taking a wide load thru Omaha and they were doing construction on the interstate. I was routed by the DOT around the construction. It was a 10 ft restriction and my load was pusing 10ft wide and I got my permit at that width. I missed my exit around the road work and was left with no choice but to go thru the contruction site. I went thru with the flow of traffic and had no problems and I had a 5 axle trailer so I was long as well as wide. What I did was against the law but I had no choice and nowhere to turn around. I didnt get caught but it just reaffirmed that you get some grace on measurments on overhead bridges and narrow bridges and such but doesnt mean you can violate the law. But an 8'6 trailer or RV wouldnt bother me on a standard road way whether in cg or on the road. I guess my confidence is higher than some but I have driven proffessionally and many ,many oversized loads on diferent road construction sites
Suppose you only had 6" clearance on a side in a construction site with the 102" trailer. If you decrease the overall width to 96" you get 50% more clearance on a side. Another way of looking at it. :)
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
