work2much
Jul 08, 2020Explorer
pianotuna wrote:work2much wrote:
Went with the Hughes watchdog hardwired on our new 5th wheel. I liked the bluetooth monitor and alerts it sends if there is an issue. I thought about their auto former but we can run a long time without shore power or use the hybrid inverter to boost voltage in load sharing mode.
Hi work2much,
Hybrid inverter chargers do not do voltage support unless you "force" them to do so. This may result in damage to the unit. DAMHIK
According to Magnum low voltage from shore will be raised during load support. Not as an advertised feature by as a byproduct of the inverter adding higher voltage and the two combining.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
