ACZL's avatar
ACZL
A very good reason Not to scrimp on surge protectors.
This past w/e we went to a new to us CG that said they had a 50 A site. Mind you, was told this was a older CG as well. Once on site, hooked up power via PI 50A EMS, went inside, turned on fridge and rear A/C. few seconds later, poof, nothing. Waited a minute, tried again, same thing. WTH? Go out to EMS box and lo-n-behold it's saying low voltage on 1 leg. Again, WTH? Have CG come check the outlet and their little radar says the same thing (low 100 volts). Just below it is a elect meter (ton of seasonals so more so for them), removes the meter, checks wires, same thing. Goes to main panel down by office and reports back that has same reading as well. Calls his electric buddy who says to call utility company cuz the problem lies w/ them/transformer. So needless to say we were able to run the BR A/C at least, micro at times. Oh, fridge even tripped the power on that leg alone. So we had both the fridge and water heater on gas.
All I can say is, "WHEW" and Thank God we had the PI EMS other wise it could have been very ugly for us. It DID it's job!!
  • Installed a hard wired one into my Coleman, 30 AMP. Measures voltage high and low as well as surge, and polarity.
    The following year was in the trailer doing some cleaning, plugged a vac in to clean up the floor and Bang, power out. WTH? Check the breakers, none tripped, then about 3 1/2 minutes since bang, click, power back on. OK now I am scratching my head(I had forgotten I installed the guard unit). Start the vac again and bang. This time I heard it more clearly, coming from behind the power panel and the lightbulb came on in my head. So I go out and look at the extension cord. Sure enough the cord was corroded causing a line voltage drop. DOH! I went and bought 100' of 6/3 outdoor cord, two 30 amp plug/socket, a UL box with 30 amp outlet and 6/3 indoor cable and wired in a dedicated 30 amp supply to feed the trailer. No more issues after that and could run the entire trailer.
    Going to do the same with my new trailer, though it is a 50 amp, and this time put a readout in so I can see the actual voltages.
  • I'm not comfortable with voltages lower than 107. I use an autoformer to correct the endemic low voltage at campgrounds. I check voltage under load before I plug in the RV.
    So far as I am aware low voltage potentially may damage motors (air conditioner, microwave) and some converters. Resistance devices are ok with low voltage--they just have lower output. The power changes by the square of the voltage.
  • Exactly why I never go camping without it, never forget to use it and have a gas/electric fridge.
  • Yes it is a good thing to have for sure. Glad that nothing was damaged for you and it worked as it should have.
