Me_Again
Jul 15, 2017Explorer III
With delayed start surge protectors that should not be an issue with the contacts.
NO one with 50 amp service should be without a good surge protector like the PI unit. I suspect the OP did not have one?
For those that do not understand the issue. If you loose neutral on a 50 amp unit, you put 240 volts across all of your AC devices.
One of the first things we did last year on our new 5th wheel add a hard wired Progressive Industries unit with remote panel.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
