RoyBell wrote:
6- Option it up. Make sure you have 3 AC units. If you travel somewhere warm, you will have enough cooling. If one goes down, you still have 2. Adding a 3rd to ours was only about $800 from the factory. Also make sure you have slide toppers. Full timing you will stay at CGs longer and all sorts of stuff will fall on your slide. The toppers will keep the slides clean of debris. Get the 3 season door so your deck is usable as a deck.
Ours have three, but you can only run two at a time. There's a switch in the bedroom that toggles between the bedroom and garage AC. Sometimes it's a tough choice.
The furnace doesn't make it to the garage either, so the garage gets the shaft for both seasons (we only have two seasons in SoCal).
