Lately I have been having an inordinate amount of condensation on the ceiling, on the unit and the outlets to my air conditioners. What am I doing to cause this? I have a 2014 Montana 3850FL.
Air bypassing from the outlet side to the inlet side will cause over cooling of the leaving air and once it is below the dew point of the air, condensation will occur on the cold surfaces.
Pull the inside cover off and check for gaps in the duct connection and baffles. Us an industrial foil tape for the sealing.
Also check for a hole around the wires back into the ceiling. Seal this with a bit of caulk.
