opnspaces wrote:
It would probably be good to know if the breaker is tripping, is it happening when the compressor tries to cycle on? Or is the compressor running and it just trips? If you reset the breaker to you get another 30 minutes of AC before it trips?
Check this link for some more tips, especially checking the drain holes while your up there. Link
also make sure you at least inspect all the caulking on the roof. You took the time to get up there, you might as well inspect everything.
I think the compressor was running when it tripped and yes after breaker cools I can run about another 30 minutes.
I have already done the roof maintenance.
