bigdave720's avatar
bigdave720
AC help needed
I got my previous low voltage problem taken care of. Holding in the 118 to 120 range now. New problem is my 14 year old Coleman Mach 15k ac.
I've had both sets of coils cleaned. New gasket installed due to small leak. Air coming from the vents stays right around 53ish degrees until outside temps start getting into the mid to upper 80's. At that point vent temps start increasing into the mid 60's. Once outside temps get into the 90's vent temps get into the 70's. Now I realize that is fairly normal. Problem is that once outside temps get into the 90's ac starts tripping the 20 amp breaker it runs on. Basically I have to shut it down completely from around noon until around 6pm daily with the current heatwave we've been experiencing for the past couple of weeks. I've replaced the breaker but that didn't help. What do I check now or am I to the point of needing to spring for a new ac?
