I'm stumped. The rear AC on our brand new 2017 Columbus is "short cycling" but with one caveat. In other threads I've read, this short cycling problem refers to just the compressor turning off whil...
In that kind of heat the fan should be set to high fan. Also make sure the filter is clean. Is it icing up? Is line voltage ample for the load? Does it normally work correctly?
