tomthyme
Jun 01, 2016Explorer
AC in the heat
So, what do you expect from your rig AC? We have a 13k BTU AC in the front/master and a 15k BTU in the living. At present, the main 15k AC is keeping the rig at 10-12 degrees lower than the outside...
dahkota wrote:
Are you parked in the sun or in the shade? It really makes a huge difference.
During the winter, solar gain can boost the inside temps 20-30 degrees above outside temps if there is no wind. Same thing happens in the summer. You might only be seeing 10-15 degrees because too much of your rig is in direct sun.
