tomthymeExplorerJun 01, 2016AC in the heatSo, what do you expect from your rig AC? We have a 13k BTU AC in the front/master and a 15k BTU in the living. At present, the main 15k AC is keeping the rig at 10-12 degrees lower than the outside...Show More
Vette_RacerExplorerJul 28, 201638 FT HitchHiker with one 15k air/heatpump unit in 100 degree heat, maintains 80 in direct sun, all depends on the insulation in the trailer.
Related ContentAC doesn't keep up with heatAC/Heat Pump Leakingheat pump/acAc/heat pumpsDominic air/heating
