ROADSTARJRExplorerNov 06, 2014A/C unitMy A/C unit fan runs all the time now,I can hear the compressor kick on and off. Has this happen to anyone?
CampinghossExplorer IINov 07, 2014I read your problem as the compressor cycling on and off quickly. If it is doing that then in all probability it is a Freon problem. If it is cooling normally then you will need to check different components to determine the cause.
