Does anyone recommend installing a second AC unit for a 27.5 fifth wheel and if so what size. I have a Jayco Eagle HT. It just takes so long to cool off. Thanks
First, do you have 30 or 50 amp in the trailer? Next, what size is the A/C in the trailer?
From this, determine if adding a 2nd unit is even doable. you may want to just up-size your current A/C.
With a 30 amp RV, you will need to see the amps pulled from the current A/C and see how many amps you can add for a 2nd A/C. With a second A/C you may need to shut down the microwave to run both A/C units.
