Bumpyroad wrote:
as one who has gone thru about 8 heat pumps at my homes I hate them but think you might as well get that option. would have to be better than a heat strip.
bumpy
Depends on where you live. In warmer climate regions where winters are rather moderate heat pumps are the way to go for a home. In colder climates they are not efficient at all. Same with RV's. If using the RV in above or near freezing areas the heat pump works quite well and saves propane. While they're work in temps well below freezing I tend to think they won't last.
