AM_AllanExplorerSep 01, 2017Accessing back side of water heaterI have a Montana Mountaineer 310RE. I turned the electric water heater on and forgot to switch the bypass back after winterizing so it was empty for a few hours while the power was on. Now it won't wo...Show More
BB_TXNomadSep 01, 2017There should be an outside cover panel you can remove to access the WH and replace the element.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
