time2roll
Jan 24, 2017Nomad
If your pump connects direct to the hard pipe then yes some flex line will be a big help. No need for an RV kit as all the stuff can be obtained at a common hardware store in the length you need.
I also mounted my pump on some closed cell foam. Still makes noise but not near as much.
Besides that IMO every closed water system should have at least a small expansion tank.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
