Second_Chance
Jan 25, 2017Explorer II
Thanks for the responses, everyone. One of the first things I did when we got the RV was to construct a foam & plywood "sandwich" on which to mount the water pump. It didn't make as much difference as I had hoped it would. I've put foam insulation on the Pex lines and used large cable ties to try to hold Pex lines away from walls and structures (this is the basement of a fifth wheel). Based on everyone's responses, I think I'll try the flex lines next - they're the least expensive and easiest to install - and go from there. Thanks again!
Rob
Rob
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
