mileshuff wrote:
Ghoullio wrote:
mileshuff wrote:
My trailer has a propane furnace. The 12VDC to the AC/Furnace thermostat comes from a circuit breaker that is located under the furnaces access cover plate. If that breaker trips there is no power to the thermostat and furnace and AC are thus inoperable.
All circuits look good, nothing tripped.
The breaker I am referring to is under the furnace cover plate (outside of trailer) and not on the breaker panel. This is on a typical Atwood furnace.
There is an off/reset switch by the squirrel cage. I tripped it and put a negative ground to the board and the motor fired up. At this point I'm considering getting a new control board.
