Coach-man
Nov 12, 2015Explorer
RustyJC wrote:
If the OP's initial post is accurate, he's tripping a GFCI outlet, not a circuit breaker.
Rusty
If the OP's original post is correct then obviously everything worked fine for four years, and unless he has re wired something the connections have not changed! GFCI can at times be touchy with something plugged in or is on in the RV! The suggestion to check what is on and what is plugged in I think is a good one! Or the OP can hire an electrician and re wire what had worked for four years. I think the OP is looking to fix this without a lot of time or money if possible.
About Fifth Wheel Group
