RustyJC
Nov 12, 2015Explorer
Coach-man wrote:
If I do not remember to check the AC after a couple of minuets the AC trys to kick in and blows the CB. Or it may be something like the hot water heater, almost anything that would draw enough to trip the CB would do it.
I guess I'll have to do a better job of quoting in the future. The above is what my post referred to vis-a-vis the GFCI versus the circuit breaker (CB). The OP indeed stated that he was now tripping the GFCI outlet (NOT a circuit breaker as referred to in your post above) immediately when the RV is plugged in, and yes, everything worked fine for years before the current problem. That's why I suggested the troubleshooting path that I did to isolate the ground fault problem.
Rusty
About Fifth Wheel Group
