the_bear_II
Jun 03, 2014Explorer
Unless you get it through the TH manufacturer, you'll probably need to have something fabricated.
I've seen everything used from EZ-UP awnings with screen side panels to family sized tents with a fabricated canvas collar leading into the TH.
At some of the larger flea markets/ swap meets there usually are a couple of vendors that supply the other swapmeet vendors with poles, coverings and parts for the canopies used in the selling spots.
The canopies can be custom sized to meet your needs. You might look for one of these vendors or someone on line that supplies for outdoor events.They could build something to your specifications that is easy to put up and take down.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
