Dayle1
Feb 01, 2019Explorer II
john&bet wrote:
I have a suggestion for your electricians. Instead of R&Ring the current AC distribution panel simply put in a 50amp panel and run a 30 amp circuit to current panel and set another panel for the new air cond. leaving spaces for future add on's.
That is what I did on previous unit. An 8 slot panel (2 for the main). The existing 30 amp panel now becomes a sub panel and some of the existing circuits can be moved from it to extra slots on the new panel to help balance the load.
Surface mount wiring also is ez, Legrande plastic from Lowes can handle romex 12/2 w gnd. I used it to add a 20 amp outlet in the garage of a toyhauler from the existing A/C down to the sidewall for an electric heater. Just cut a small notch in the A/C shroud for the wire chase to exit (or in your case, enter) the A/C.
Biggest cost is the new 50 amp power cord.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
