jodiesel2's avatar
jodiesel2
Adding a 2nd battery
While dry camping in chilly weather it became apparent that I needed a second battery. I purchased an identical battery to the existing. I'll be routing large diameter cables to connect the 2 together via the posts. These units have both automotive posts and studs. All of the trailers connections are on the studs. My question is, should I split the trailer's connectors between the two batteries or keep them all connected to one battery?
Thanks
  • You should split the trailer's connectors to make them draw more evenly. Also, if your current battery is more than a year old, I highly recommend that you change both of them, and if you have space, buy a real deep cycle battery or batteries rather than another RV battery.
