N6761U
Jul 01, 2014Explorer
I added the coleman mach 8 13.5 to my Big Country before we left Northern Ca. last month, glad I did. We first went to the Las Vegas area and it was hot. The second air worked great, helped to keep the 5er nice and cool. Once we went over Vail pass in the Rockies, didn't need it any more. Rain wind and more Rain. Now it is starting to warm up and should be needing it. Installed it myself, piece of cake, did need longer bolts for the install. You will need help to get it on the roof, weights about 90 lbs. Need a heat gun to help remove the old caulking from on old vent, just follow the instructions to crank the bolts down to seal the gasket and its a plug and play. There are some videos on You tube that show how to install if you need a little encouragement. All in all, I would do it again.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
