nayther
Oct 25, 2018Explorer
westernrvparkowner wrote:
If you are going over the vinyl, not stripping to the subfloor, I would be using screws, not adhesive. The vinyl is designed to be a non stick surface so it can be cleaned. It is also softer than the diamond plate, so you will get flexing that will weaken any adhesive bond over time. On top of that you will be stressing whatever is bonding the vinyl to the subfloor, creating more weak points. Screwing it into the subfloor seems to make more sense.
good advice here IMHO
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
