MFL wrote:
My FW has the equa-flex suspension. I see no adjustment to raise or lower the equalizer. My spring end brackets have only two holes, the one the bolt is in, and one two inches lower.
I too, am doubtful that lowering the ends two inches, will actually raise the trailer two inches. I would just like to be as close to level as I can be, when towing.
Thanks,
Jerry
Both of the Jayco's I raised towed better after, less chucking. They both had Leland/Dexter frames, and had 3 holes at the ends and 2 at the equalizer. Sounds like you will gain about 1 inch
