tinner12002
Jun 17, 2018Explorer
Reflectionwoes wrote:
Wow! Thanks to all of you! To fill in the blanks the rest of the story is after taking all the measurements and reviewing with Lippert and taking it to 2 frame shops, our suspension was installed wrong, which has caused the equflex, bushings to wear out. Rob and BO are right on, axles are fine, they are simply too light for the rig. In the reviews I found, Dexter is the best, but way out of budget. I am leaning toward the Timbren but thanks to all of you I am going to get a second opinion and price for the More Ride. Ric
Are you saying the Dexter axles are way more expensive than Lippert axles, I didn't think there was enough difference in cost to say one was way out of budget. If budget is an issue then I would look at, as others have mentioned, installing the Dexter ez flex system with wet bolt and shackles, about $400 for the kit. Axles for 2 7000lb axles with brakes about 900-1000 for the pair. About $1500 in parts and you'd have all new axles and suspension.
https://www.ebay.com/itm/Dexter-Axle-E-Z-Flex-8-000-lb-Tandem-Equalizer-Suspension-Kit-7-3-4-K71-653
About Fifth Wheel Group
