SH
Nov 05, 2014Explorer
DaveInVA wrote:
Greetings everyone, I have decided to go with a used Bighorn or Big Country for full-timing in Northern Virginia.
First, I think Heartland makes a good rig and some day may decide to own another one. I also think highly of their Customer Service and their great Owners Club. That being said, I can tell you of a few small issues we had when we purchased a new Big Country.
Ours was gray. The front and rear gel coat caps faded severely within two years. The entire rig was pristine except for the ugly caps. Painting was the only fix. If the one you are getting is gray, don't let anyone tell you it can be buffed out!
All the vinyl insert trim got hard as a rock and had to be replaced within a year. It cracked and fell off. The new stuff lasted fine.
The front bulkhead area under the cap was prone to leaks as was the front storage cargo door wall. Had to pull the trim, replace the butyl, screws, and re-caulk. The aluminum support frame of the front cargo door broke welds. I fixed that with some gussets and pop rivets. Look for ripples in these areas.
The metal wrap around at the roof and wall joint was separating in many areas (lifting from the roof). Didn't have the opportunity to fix that before we replaced the rig. Very easy to see though!
Do a good walk around, climb on the roof etc. Doubtful you will find any interior issues but a lot is determined by how the previous owner cared for it!
Best Wishes!
About Fifth Wheel Group
