importman
Feb 27, 2016Explorer
Advice needed on permanent setup
Hello All, I've just bought an 06 Montana with the intention of setting it up permanently for my elderly mother to live in. She has decided she would like a smaller area than her house to live in and have to clean up. The fiver hasn't been delivered yet but I'm contemplating what I'll need to do to have it functional for her. I'm planning on running water, electrical and septic lines to one area of the yard and basically have it set up like a site at any campground. I hope to have it where her new home and my current Outback can park side by side and share a service pole for the electrical by installing both 50 and 30 amp breakers and receptacles. I also will install a freezeless water spigot. My big question is on the sewer system. Will I have to remove the black tank and plumb directly into the septic system? I'd prefer to have a setup similar to a campsite or dump station where I can also flush/dump my Outback when needed without having to go to a lot of trouble to unhook the sewer line from the Montana. Also, if I do remove the holding tanks, will I be able to plumb this using the existing toilet or will I have to buy a residential type? Any and all advice on this subject will be greatly appreciated. A few other questions I have are:
1. Should I plan on using blocks under it for more stability or will the stabilizers be sufficient?
2. Does anyone have any ideas on tying down a fiver like the way mobile homes are tied down?
3. Do I need to use a kingpin support?
4. Any other advice on this setup? I'm sure there are some things I haven't thought about.
Thanks in advance for any help/advice you can give me concerning this. I always appreciate input from anyone generous enough to share their knowledge.
