schlep1967 wrote:
cummins2014 wrote:
schlep1967 wrote:
I've been using my Pullrite Superglide for 10 years. If you can read and follow directions, hitching and unhitching will not be a problem.
In those 10 years I have unpinned the head and lifted it off the hitch to unhook one time. I have been in that same site over a dozen times since and haven't had to do that.
Its always going to be a problem if you are not within 15 degrees . If someone enjoys unpinning the head to get unhitched ,well then go for it.
So what does it cost to pull forward 15 feet and adjust the truck straight? A lot less than a broken window.
The knock here if that’s not possible to get straightened out , he!! I have pulled out numerous times at an angle , no worries not having to jockey the truck around to get unhitched . As said go for whatever you do to get unhitched . They are not an easy hitch to use , some have been unhappy with them . People need to be aware of that , they are not as great as people make them out to be .
