dpgllg
Mar 29, 2017Explorer
RedRocket204 wrote:
OP,
There are multiple fold-up tricycles listed on Amazon that give the fold up dimensions. Since you have an 8 ft bed, you may be able to just load two trikes in the front of your truck bed and not have it interfere with trailer movement. May be worth looking up your specific bike's fold-up dimensions and roughly measuring it out in the back of your truck. Then do a test run without moving the truck, etc.
Here's an example of one since you don't have the specific brand/model listed: Amazon - Worksman Port-o-Trike Three Speed Adult Tricycle Blue
Measures 30 by 31 by 29 inches (W x H x D) folded
Also, that is not something you are going to want to lift up to a roof mounted bike carrier since shipping weight on that linked bike is 70lbs, expect the actual weight around 60lbs +.
Thank you so much for the response unbelievably you selected the one trike that I bought! I now know the weight and folded size so I can see what room I have to work with inside the RV and in my truck bed.
laknox wrote:dpgllg wrote:
Do to illness I have acquired an adult tricycle to ride while camping. It is a folding model where the frame folds the front wheel back alongside the frame and between the rear tire.
I have not tried yet but I imagine it might be a little difficult to put the trike inside the RV for transport. Also I'm not sure if it will fit in the back of my truck in front of the hitch without causing an issue. I do have an 8 foot bed.
I do not have a hitch receiver on the back of my 5th wheel to add a cargo tray.
If anyone else has encountered this situation how did you resolve it?
To further muddy the waters my wife who never rode a bike in her entire life wants a trike of her own now once she saw the trike!
Any advice is appreciated!
Dave
Were I in your shoes, I'd find a =good= trailer/welding shop and simply have them replace your rear bumper with heavier gauge steel and add a 2" receiver on it. Get a basic $100 cargo rack from Harbor Freight or Walmart and load 'em up. I had this done on my FW and my welder said it would carry 300 lbs, no problem. Only loss was the bumper tube was just enough smaller ID that the stinky hoses would no longer fit, which was not an issue since I never carried them there anyway. My welder was also able to drill out the pop rivets holding the outer decorative sleeve and reuse it on the new bumper, so it still looks great. Just notched it to fit over the receiver.
After thinking about this for a couple minutes, I remembered seeing cargo racks with a ramp on one end. Just roll your trikes up and strap 'em down. Worst case, have the shop modding your bumper build you a nice aluminum rack. Save a bit of weight hanging from the bumper that way.
Lyle
I started to look into this but none of the local hitch or RV shops want to perform the work for liability issues. They stated putting a receiver on the back would potentially allow me to attach a trailer which my 5th wheel would not support. I can keep looking to find someone. This applies to all the other responses regarding putting a cargo rack etc. on the back of my 5th wheel.
GMH wrote:
I like Lyle and Roy's ideas. You could also maybe look at switching to a toy hauler type 5th. Then you could just lower he ramp and ride out!
If I could I would pursue a new 5th wheel but due to my disability my income has been significantly reduced. A new 5th wheel is definitely not an option at this time.
SanMarMor wrote:
If you have an 8' bed, you shouldn't have trouble with it being in front of your hitch. I carry two standard bikes in front of my hitch in the bed, along with other items. That's assuming getting the trike in and out of the bed isn't an issue for you. It also wouldn't be real easy maneuvering over the hitch to get to the front of the bed. But there should be plenty of room.
Mark
The only concerns I have is getting the bikes over the hitch. My wife and I can lift them onto the back of the truck but getting it over the hitch might be a real problem. I will look at this to see what it would take.
dpgllg wrote:the bear II wrote:
I would measure the door opening of the 5th wheel to see if the trike will fit through the door upright or on it's side. If it will fit then I would get a heavy moving blanket, lay it on the floor and put the trike in the 5th wheel. Place some large empty boxes to brace against the trike and a wall or other solid surface to hold it in place if you don't have a way to secure the trike with straps or rope. I've carried a mobility scooter and wheelchairs this way in our 5th wheel.
Now that I know the exact size of the trike folded I will definitely look into this approach. I like the idea of the moving blanket and empty boxes as well.
THANKS TO ALL WHO HAVE RESPONDED!
If anyone has other ideas please keep them coming. We have a trip scheduled April 26th and it would be great to take the trike.
Dave
Message got truncated
About Fifth Wheel Group
