rhagfo wrote:
MFL wrote:
cummins2014 wrote:
Why all the advice on 250/2500, knowing full well the 1 ton is the better choice in many ways :h
" Really hoping to get by with a 3/4. It says hitch weight is 1338 with a GVWR of 10195."
Above per OP statement
Any late model 3/4 ton will easily handle this trailer, without even being close to going over ratings.
If someone asking, was absolutely considering a truck, that in my opinion was not safe/capable, I'd be the first to advise them of a better choice!
In many states GVWR is just a class regulation for insurance/registration. In states that do consider GVWR for registration, you only need to pay for it. Now you are good for 12k GVWR on your 25 series truck. It is the axle/tire ratings that matter, and if the tires are up to it, yes, bags can make the 3/4 ton do any job the 35 series SRW will do. If you see a bigger FW in your future, such as Russ may be considering, then get the 35 series DRW now and be done.
If you are considering a FW with a GVWR of 15K, yes, I'd say get the 35 series SRW as a minimum, and if full time is in your future, a long bed DRW truck a better choice.
Everyone does not need a bigger truck than needed for the FW they are wanting to buy!
Jerry
Well the 1,338# DRY pin on a GVWR of 10,195# at GVWR pin could be 2,020# at 20%.
Granted in Oregon I don’t pay any more for our 3500 DRW, than we pay for our PT Cruiser.
I’m fully aware that the OP’s choice of fifth wheels the 3/4 ton will do nicely , but IMO a mistake. As said have seen it many times . I could care less once a year if I’m paying a few dollars more for registration. Here in Utah I have no idea if there is a difference in fees.
