DJMeeka
May 16, 2020Explorer
Advice Please - Airbags & Weight Distribution Hitches
I just bought a new to me 2018 Cruiser RV Stryker ST2916 toy hauler with about 1300-1400 lbs of tongue weight (will change when loaded). I have a Blue Ox Sway Pro w/1500 lb bars. I am towing it with a 2014 F250 CC 6.7 4wd with a 4" lift. When I picked it up, I only had a weight dist. hitch. It towed ok but I noticed the rear sagging a little more than I like and it had a jarred ride over bumps. So I installed a set of Airlift 5000 airbags.
My question is, what is the correct sequence to connect the trailer with both the weight distribution hitch and airbags? I've read that you should air up the bags a little (15-35 psi but depends on tongue weight and weight in the truck bed) then connect the trailer and weight distribution hitch. Goal is to have a smoother leveled ride when towing.
Hoping to hear from someone that has a similar combination.
Thanks
Thanks
