Ivylog
Oct 19, 2014Explorer III
Sorry for taking your additional info the wrong way and Thanks for your Service. With your F450(6.4)I'd recommend buying more trailer than you think you need... one time as trading can be expensive. I'm a used guy too but water leaks are often a problem. Any wavyness to the sides of soft spots is usually water damage. Any stains to the inside is suspect so crawl all over the roof looking of any seals/seems that have a crack in the sealant. I am not a fan of rubber roofs so a fiberglass roof would be a plus. I would look for a 5-6 year old (4 season) rig that's been store under a roof but it will probably need new tires. I only put two year old used takeoffs tires from a PU on my many trailers as they age out before you wear them out.
About Fifth Wheel Group
