dfb wrote:
krazymatt wrote:
Depending on your tow vehicle there's probably no doubt that it will pull it especially if its' a diesel but the problem arises if you get in an accident where someone gets hurt or killed and the lawyers will have a field day with you for negligence.
Not true! Insurance pays if the fault is yours. No regards to weight. If the other party is at fault, the weight of your vehicle is not relevant. In either case, you and your vehicles are insured. The only issue is who is at fault. Weight is not an issue. Where does thus stuff come from?
Well Sir if you are over your weight ratings and you kill one of my family members I will drain your insurance coverage then I will go after you personally. And I will win and you will have nothing.
So if you want to play roulette by towing over your limits you better have a huge umbrella policy.
